Dishwasher
16 Oct 2010
My bosch dishwasher keeps draining even when door is opened when I change programs it just keeps trying to drain
Sounds like the antiflood device has kicked in because of a leakage. Tip it forward & see if any water runs out (lay a towel down first). Then try a restart. You'll probably end up having to track down the leak. Post model & E number if you need further info.
many thanks to zipper & leccy758 took machine apart and leak was where you said it would be hopefully it will all be ok
