- Joined
- 27 Sep 2006
- Messages
- 3
- Reaction score
- 0
- Country
Folks,
Our 1989 Gloworm Hideaway has the CH pump mounted directly above it.
When the pump starts, there is the sound of rushing air, which then "bubbles" into nearby radiators.
The noise only occours at start-up - there are no notable air sounds when the system is running. And it only happens after prolonged use of the water heating. There is no electro-mechanical valve, so, if the radiator valves are open, some heat transfers to the radiators without the action of the pump.
I recently re-routed some piping to a bathroom radiator, which gave me opportunity to drain down add some "Sentinel" X400 sludge remover. A visiting gas engineer had suggested that the boiler sounded fairly sludged. The sludge remover was left in for around four weeks, and the water was quite brown when drained out. One 1ltr pack of Sentinal corrosion inhibitor was added on refilling.
Any new piping done during the move was tested "heated" whilst still accessibile under the floorboards, and was totally dry. We have no stains on ceilings. Yet (!)
There are no "dripping/hissing" sounds from the boiler when running, which might indicate a moderate leak.
My suspicions are;-
1/ The sludge remover was left in a bit too long, and has actually disturbed corroded joint face areas that have started off a leak. The system has, however, always run with some kind of inhibitor.
2/ There is a leak on some of the new piping - unliklely, as no external signs, but always worth considering. The work was at one of the highest points on the system, and no noises can be heard.
3/ There is not enough inhibitor in the system, (11 radiators, some long, some double-row) to purge out the oxygen. But I have my doubts about this. It may be a "first step" to add another couple of litres, I guess, and see if the problem goes away. It may be that the action of the water heating, when the pump is off, is separating oxygen off, which is gathering by the downstream side of the pump, causing the "rushing" nosie on start-up.
4/ After 16 years, it's time for a new boiler anyway, and the sludge remover has only hastened the inevitable.
5/ A small length of push-fit plumbing, added by a "professional" during house extension work nine years ago, and clearly "floating around" under the boards (but inaccessible) has degraded. (I can't understand the rush to "push-fit" - from many years of car work, I know that rubber seals, subjected to heat cycles, degrade over time.)
Any help and suggestions much appreciated. Can anything be added that would seal leaks but not clog the system? This is common practice on car cooling systems, of course.
Despite the screen name, I'm a DIY-er, moderately experienced at plumbing jobs.
TP
My suspicions are;-
TP
