New to all this so go easy please
Just moved into my first house, 1935 brick semi. I've stripped the wallpaper (thick, strong patterned) off the walls with a steamer to find a reddish-brown smooth coating, maybe 0.5mm thick. This has chipped off in places and I can see pinkish-white plaster (I assume) underneath.
Searching the forums I get the impression this brown stuff is some kind of oil-based distemper? The steamer did cause it to run, and if I rub it with a (cold) wet rag it comes off rust-colored.
So, is it distemper? If so, how do I get it off? I read someone suggesting to blast it with the steamer and scrape but I'm a bit worried about damaging the plaster. Is that the way, or any other way?
As the icing on the cake, at the top of the walls where a picture rail used to be (I assume, since it's still there in one room), the surface is light grey and chalky - comes off as dust if I rub it with my finger. Am I right in thinking this is water-based distemper? If so, again how do I get this off? Sugar soap, brush, sponge??
Really grateful if anyone can help. Total novice so please assume I know nothing
Mark
Mark
