Distrubting Power at bottom of Graden - 32A Feed
15 Nov 2021
I have a simple (I hope) question. I am planning on supplying electricity to a Pergola at the rear of my garden.
I would like to supply some LED lighing and 2 x 2KW Electric Wall mounted heaters and a water feature pump. If I run 6mm SWA cable from Garage CU to rear of garden (on 32A MCB) is there a power distibution switch I can get to take the 32A in and supply 3 x 13A out on a switched box?
If not how do you distribute the power? Do I need external CU?
As said on another post
512GV_P
the EV charging unit allows RCBO and socket in one unit. From picture
ae235
it seems to have room for a second RCBO, so possibly will do what you need?
