Am I allowed to fill in a disused drain that takes gutter water from a small section of roof. I have rerouted drainpipe. The drain in question in on a path at side of house. It is only 1.5m from a main inspection cover.
My slight concern is 'gases build up' however there are two in use drains at front of property 3-5m away. Actually if there is a u bend in these drains my comment about gases is irrelevant.
I would fill in with a light breeze block then cement, so that if the drain was ever required in future it would be relatively easy to Re reveal
Does this sound OK?
Thanks in advance
Does this sound OK?
Thanks in advance
