- Joined
- 22 Jan 2006
- Messages
- 67
- Reaction score
- 0
- Country
Strange one this...got a 7 year old Ariston 27 MFFI with a Landis digital timer unit and ext. thermostat. Hadn't had hot water for a while and the system was making a lot of screeching noises and then the timer stopped working other than the over-ride boost button which is the only way we could get CH (but still no hot water). Called an engineer in (this was after the first one told us to simply get a new system because a new diverter valve alone was £200+...sussed he was an idiot fairly early on) and he fitted a new diaphram and we got hot water (hurray!). He checked the wiring and said the timer unit and the thermostat had been wired incorrectly and that there were at least another 7 wires going into the spur (in which the timer and thermostat were running through) that he couldn't explain and nor could I. He said the system simply needed a live feed and the timer unit on the Ariston itself was perfectly adequate. I agreed and he disconnected the timer and the thermostat.
Since then we've had hot water - the system kicks in after a couple of seconds when the hot water tap is turned on but despite setting the in-built timer and trying every setting possible (over-ride, continuous, timer activated, etc) the radiatots don't get any heat. When the system is activated the gas fires up but shuts down about 15 seconds later and the whole unit makes a lot of gurgling noises (not unlike when it is running OK).
Tried turning off the rads, bleeding, etc. but no luck and the engineer has disapeared off the face of the earth. Loath to get another in before I have some idea myself...any ideas?
