I have a Gas Board heating and hot water system which uses a Glow Worm boiler with a Honeywell room and cylinder stat, Randall time clock, Honeywell three way motorised diverter valve and WSP pump.
When the time clock is set to "time" or "constant" with the room stat calling for heat, the diverter valve used to switch over to heat the rads as soon as the hot water cylinder reached temperature.
Suddenly the valve would not switch over so I first replaced the valve believing it to be faulty, then the stat which has made no difference. If I use the valve "manual" override lever, the rads will heat.
Can anyone please tell me what else could have gone wrong?
