Hi all
I started to clear out my bathroom this week and plan i DIY job for a full refit - bathroom suite, flooring, tiling - the works! - And im knackered already (its only Tuesday)
The room is now pretty much empty bar a few capped off pipes and i am now doing the pain staking work of preparing the walls for tiling and fitting a new window.
I am needing to decide where the sink, toilet and bath feeds will need to be located soon as i will be wanting to fit laminate flooring in next couple of days. I want to move the existing route of the pipes to reduce boxing in. The hot feed is 22mm to the bath, with a 15mm running from it to the sink. On further examination under the boards the hot seems to originate from a 15mm pipe increasing to 22mm - Is there a need to keep it this way? any benefits?
The reason i ask is that i need to take it back to the point where it is 15mm in order to re-route, so therefore if there is no reason to increase it to 22mm i wont. It seems that in the past, the length of 22mm pipe had something else running from it, but this is now capped off.
any advice much appreciated.
Ste
Ste
