Hello Chaps!
I am looking for some advice on a DIY job I plan on undertaking in the next few weeks/months, as per a previous thread my Kitchen is single skin brick – garage conversion. I did plan on ripping it out and lining the walls with insulation, this is would have been a massive task and likely a new kitchen so… My previous post highlighted the use external insulation which we have decided on going with, I just need to know more about the solution, are there any limitations or prerequisites I need to keep in mind? I also need to know what thickness to go for, my understanding is the thicker the better in terms or heat retention but the R-Values don’t seem to change greatly between boards. I am looking at Kingspan K5 Kooltherm @ 70MM with an R rating of 3.5 or Celotex SW3000 80MM with an R rating of 3.05, the Celotex is 10MM thicker and has a lesser R Value BUT is cheaper @ £16.74/m2 inc VAT rather than £18.75 inc VAT for the Kingspan.
I have measured up and I am going to need about 30m2.
I Also need to know more about the finishing, I would ideally like it to look like the rest of the house but the cost of the brick slips scares me! So, I am thinking that we use the slips where visible and then render up the side of the kitchen where its only seen by my neighbor when in their utility room.
I need to try and identify the bricks we have so I can get a price on the slips.
Can anyone help me out with a shopping list?:
1) Insulation boards
2) Fixings
3) Base coat??? – is this needed?
4) Mesh sheet?
5) Undercoat?
6) Face finish – Slips or K-Rend?
What else am I missing.
Any help would be amazing.
2) Fixings
4) Mesh sheet?
5) Undercoat?
