- Joined
- 28 Dec 2023
- Messages
- 21
- Reaction score
- 0
- Country
Hi there, I'm constructing my own Garden Room / Workshop at the back of my garden right up to the boundary under permitted development. My total height is going to be 2.5m at the tallest section, with flat cold roof, but to achieve this height I'm having to use 5x2s for the roof joists. As the span between the front and back wall is short enough (2.5m) it allows me to use 5x2s which will help to carry out this plan. However, I read somewhere that cold roof has to have a minimum of 50mm cavity. Is that required by building regs and cannot be any less than that? It would be ideal to use 90mm PIR boards for the roof which would leave 30mm cavity for airflow below the OSB roof sheets. If building regs require 50mm ventilation then I can either go down to 70mm insulation boards or use 6x2s and reduce height of my walls, the latter being least desirable as plan is already set out and I already struggled with low headers for french doors, window etc. if I go down to 70mm insulation will my roof be actually cold!? Any thoughts? Thanks!
