H
HiZ
Hi all,
Looking for some advise as Im shortly due to replace the galvanised metal facia/soffit boards and asbestos guttering. Its 1959 semi and I am getting my dad to help. Im also getting some aluminum scaffold for the weekend. Local council tip will accept asbestos gutters too which is a bonus.
Existing facias are 150mm heigh/25mm thick and soffits about 280mm deep.
1. Want to replace the steel totally so do I just get the plastic facia and vented soffit from the likes of screwfix etc.
2. How/where are the boards fastened up, is there a good diagram showing this anywhere. Obvuisly I use the right fastenings with plastic caps etc. The soffits are resting on the top of the outer wall, are they screwed down into the bricks from above?
3. Is it as simple as pulling the old down and replacing with new, was reading on a supplier site that the pro's take the first row of tiles off and fit a plastic/rubber membrane. Again, is there a diagram or is this essential?
Any help appreciated.
Cheers
Cheers
