Hi all, great forum, I've found lots of help already but now I need some guidance.
I want to put two, 2 way lighting switches in our rear entrance hall. There is currently a single gang switch (2 way, common and L1 connected) but this is in the wrong place. I can run new cables and locate new switches myself but it means replacing the old switch with a blank faceplate with connections made via a choc box in the redundant backbox to the new switches. All cables will then be run in verticle and horizontal safe zones within stud / plasterboard partitioned walls. As a diy'er am I legally allowed to do this?
2nd problem!! - Local electrical shop sold me 2 core T&E instead of 3 core & earth. Is it ok to run 2 lengths of T&E using brown and blue (sheathed brown) for L1 & L2 then the brown from the 2nd T&E for the common? All wires will be sheathed brown as they will all become live at some point.
Thanks for any guidance.
