Hello,
Never done this before but I am going to put in couple of doors (1981 x 762) between living room and dining room and had some questions if someone can advise. If it sounds like I don't know what I am doing....
I cant seem to find a premade door frame do I need to get the timber myself? What dimensions would you advise (3 inch wall with dot and dab 12mm plasterboard either side)? I was thinking something about 120mm deep?
... then I would need the door stop bead, what size is this?
Is it a good idea to use a pair maker. Just wondering as this will obviously affect the width measurement?
With regard to measurements, what would you add to the width of the two doors? I was thinking 4 mm. Is this OK? (i.e. frame width 2 x 762 + 4mm = 1528)
Would you allow 20mm at the bottom of the doors?
sorry if this is a lot of questions. Any advice would be very much appreciated
