I don't do a lot of decorating and need some advice.
I have stripped the old embossed painted wallpaper off my living room walls and i am planning on re-papering.
The problem is that one of the walls is a kind of wooden (almost MDF looking) another is plaster board and another is concrete... strange i know!
All three of these walls are causing issues when it comes to getting every bit of old backing paper off.
As i try and remove backing paper from the wooden wall it takes strips of the wood covering off... The concrete wall has loads and loads of little holes in if i take the remaining backing paper off and the plaster board outer layer peels off when i try and remove the backing paper.
I know the best wall prep is to strip it all off and patch up etc.. but im planning to use a high grade lining paper and seem to be making my walls even more bumpy by trying to get the backing paper off.
Would i be ok to just go ahead and put my lining paper up and leave the backing paper thats left up?
Any tips or advice would be greatly appreciated.
thanks
thanks
