Hi everyone, novice diyer here. Just scoping out whether I can do a job myself, also had conflicting advice from trades so wanted to ask the excellent hive brain on this forum!
Currently renovating the bathroom. Tiling all done and shower tray and bath installed.
I want to install vinyl click flooring. It's an old house so has traditional 20mm floorboards. My plan is to install a 6mm cement board subfloor. But I have a few questions I need help with.
Plumber says it needs a flexible rapid set tile adhesive (S1) first and then screw in the cement board with 25mm screws.
Had a flooring chap round this eve for the rest of the house and asked him to quote me anyway for the bathroom flooring with labour only. He said no need for tile adhesive with vinyl click and to screw it in directly to the floor. I've installed laminate myself easily enough over floorboards and only ever needed a floating woodfibre underlay so it made some sense to me.
So what I need to know is who is right?
If I did do this myself, assuming I didn't need rapid set, I've read the Turbo Gold wood screws are good for cement board. Would that be a 3.5 20mm size? If not which screws would you recommend?
Thanks in advance.
Thanks in advance.
