Hi all,
(I don't live in the UK and English isn't my primary language; however I'm hoping I can get help here as this forum seems to be the best one for Vaillant-related DIY questions)
My story:
in the apartment which I own we have a Vaillant VCW 180 XEU boiler for both, hot water and CH. Last year we began to experience some troubles with the heating - the boiler would work very irregularly, sometimes heating-up, sometimes not. Hot water worked reliably.
A few days ago we tried using the CH again and it was a no-go. Hot water works just fine. We called a Vaillant-certified repairman who told us that we either need a whole new installation rounding up to 3k or a major repair of our boiler. BUT he also announced that Vaillant does not supply parts for VCW 180 anymore and that he won't be fixing our boiler using old/used parts (probably due to warranty/insurance issues).
He did however give us a list of broken/needing-replacement parts (the list is in German, I hope translation makes sense):
- Priority Switch Valve #12-684
- Servo Pressure Regulator #05-0164
- Electronic Regulator (PCB) #25-2947
[ to note here: the main pump was replaced 3 years ago ]
I was able to find all these parts on eBay and they are coming in a few days. As we aren't able to find anyone who'd install these parts for us I'm thinking of doing it myself. To be frank I don't have any formal engineering education but I know how things work and also that threading on gas pipes goes the other way. I have repaired car-engines, know how to weld and generally good with electronics. I have a good toolbox too![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Now, can you please give me some hints and advices on how not to make things worse and to succeed in my undertaking? I know it is a risky matter, so I don't need to hear about it again; I wouldn't be doing all of this if I could cash-out for a new installation. I realize though that I can't be running a boiler from 1989 for that much longer, but during this winter it has to work!
- Do I need any special, Vaillant-specific tools?
- Do I need to care for torque specs when screwing things back together?
- Shall I be replacing seals when changing the above mentioned parts?
- How to properly refill the system after it's put back together?
- Any other parts which might be good to replace once I'm at it?
Greeting to all from Berlin!
Daniil
My story:
Daniil
