Morning all, as the title, i am stripping back my original sash windows from my Victorian terrace they have lacked serious TLC in the past. Bit of dry rot to treat but i have an idea on how to do this. My question is though it took me ages to get all the putty out, really past its best before date, brittle as hell and just crumbled.
Now when i put new glass back in 6mm single pain (not able to put double glaze units in due to the size of recess, i know its not brilliant but its better than the original 3mm, weights added to cast weights to suit), i don't wish to use putty so what can i do? The timbers aren't completely flush so thought about applying a little white silicone around the edge of the pain to get a seal around the wood. Then add a little silicone to the bead trim and wipe excess of to get another seal. Painting windows white so shouldn't be visible too much.
Is this acceptable or is there a better method? Would love some advice, tips as i have 6 complete windows to do! Weather starting to turn should i just put this off till the spring?
Cheers
Cheers
