- Joined
- 12 Feb 2017
- Messages
- 84
- Reaction score
- 1
- Country
I've been messing around with some 2nd had solar thermal tube collectors I've been given and found. So far I've got 60x 1.8m Kingspan thermomax tubes in 2 30 tube manifolds heating a 200l megaflow cylinder and a 4000l water storage tank I've converted to a hot tub / pool. I've only cobbled things together with garden hose and jubilee clips to prove concept which seems to be working well. My question is how do I know the heat output of the system in kwh. To know if its worth preserving with and spending money on to make it more permanent and reliable? When the tanks heated up to about 45C it switches over via a 3 port valve to the 4000l tank which it can approximately give 1C increase an hour on a good sunny day around 12noon ish. But I want to be able to measure the kWh over an entire season, so i'd nee to know the volume of water and the temps coming off from the solar and returning to the solar panel right? does such a thing exist?
