DIY surgery and pipe freezer
30 Dec 2018
Up North
For the past couple of months, I have had a skin tag growing in a rather awkward place - on my upper lip and every time I wet shaved, I would catch it, cut it off, then it would regrow - rinse and repeat.
Reading up on the subject, there are three ways to remove them - cut it off, or put a tight cotton tie around it, or use a freezer kit. I had cut it off a few times, didn't fancy cotton dangling on my lip, so that just left freezing.
I remembered having a wart and varooka(sp?) freezer kit somewhere around, but the freezer aerosol had leaked, though there were plenty of the sponge bud sticks still with the kit. My next idea was pipe freezer aerosol, which might be the very same substance as in the medical kit, but much cheaper and which I eventually tracked down in my workshop. A bit more Internet research suggested the two were identical substances, so I gave it a try on Tuesday evening, following the original medical kits instructions.
Soak the sponge in freezer spray, hold sponge down for 15 seconds, then apply to the skin tag for 15 seconds, head back so sponge was applied down. It went painfully cold, my lip was still a little numb 24 hours later, but 48 hours later the tag has gone and just a bit of a scab where it was.
I used to remove my own ingrown toenails, with razor blades and lots of sweating..............
.....but without lasting success.
I removed one from under my arm once with a bit of cotton tied round it. Took a few days and it dropped off. If I had one on my lip though, I’d get it done properly by a medical professional.
The will not do anything cosmetic, especially true now with the present circumstances.
I almost amputated my little toe ! The pain was that bad - I went to doc and chropodist , both saw nothing . It was an arthritic flare up - I kid you not it was worse than having a new knee due to the arthritis. Bizarre for such a small member ;)
I tested a beauticians kit and she had a skin tag removing service, she sorted my wifes boss who had a whole village of them on her neck ..yuck
