MY DIY TIP OF THE DAY—Bath Edging trim.
If you don’t want to see that ugly silicone sealant around bath--- Buy one 5 metre length of (12mm or 19mm Window Quadrant trim) cost is low at about £1.50p. a length. Clean away that old silicone sealant and then fill the gap with new white or clear silicone sealant that will stop any water that might seep down the gap. Mitre the corners of the Quadrant Trim and put fine beads of silicone sealant on the two inner edges of the Quadrant trim. Then press into place on the bath. When it is dry put very thin beads of silicone sealant on the very edges and corners.
