Firstly, what tools do have access to?
What thickness is the timber you wish to work?
and how thick is the timbers you wish to younger and grove?I have a router, a circular saw and a plunge saw.
you need a spindle moulder with a power feed.Hi All,
Can anyone tell me the best way to tongue and groove timber? I've about 50m to do so don't mind buying kit, just wondering what's the best technique? I want approx 10mm tongues/grooves.
thanks!
S.
That will almost certainly fail because getting the cuts to line-up properly on multiple passes on a circular saw with very long stock is all but impossible to achieve in practice even in a trade shop - that's why they use spindle moulders and power feeds for the task and do the cuts in a single pass (and why even router cutter sales places sell sets which will cut either tongue or groove in a single pass)If your saw table is a decent one, and you have someone else with you, I would consider using this to cut both the tongue and the groove. It will probably take a number of passes to do the groove, by moving the fence out slightly after each cut, but it can be done.
