- Joined
- 7 Feb 2017
- Messages
- 24
- Reaction score
- 1
- Country
heres what ive got .
30 year old potterton netaheat
DIY ufh down stairs (not finished/connected)
30 year old potterton netaheat conventional boiler in kitchen downstairs
4 rads upstairs with thermostatic valves +heated towel rad with lockshields
cylinder ,pump and 3port valve in airing cupboard with wiring box .
system has no room stat anywhere . just on the cylinder .
So im thinking i need to make it S plan for independent control of each , chop out the 3 port valve to start with .
put in 3 two port valves (on the right pipes)
one for the cylinder one for rads and one for ufh
sounds easy... i think .
Will that work if im only using upstairs rads or ufh ?
how would the final temperature be controlled/limited if the hot water cylinder stat never gets hot?
can the boiler limit itself....i think not?
also do i need some kind of auto bypass somewhere ?
any help appreciated .
