Has anyone done a DIY upgrade of an old British Gas Smart Linked Thermostat to a Hive receiver?
Do the two receivers require exactly the same cabling? Is it simply a question of removing the BG receiver, replacing it with the Hive receiver and reconnecting the same cables?
Even better, are the backplates of the two receivers compatible - i.e. do you simply need to remove the front part of the BG receiver and replace it with the Hive receiver?
