evening all i have conventional vented boiler system with header tank in the loft.
Last winter i had two TRV's which are leaking quite badly and i tried using some ptfe tape and no luck.
So i've done a fair bit of diy around the house, such as fitting new doors, staircase and i've done some work on car interiors and electrics
three methods i've seen to do this, i've been watching a few videos and I really want to be able to do this but i'm now finding myself bottling it thinking i can get myself in a right state.
three methods i've watched
freezing the pipe with a spray can kit and swapping the valve out - doesn't seem popular or it doesn't seem to work very often and when it does it lasts about 5mins and i will need longer
using the rubber bungs on the vent and cold feed in the header tank and then swapping out the valves, saves draining down the whole system- bungs sometimes fail and i read somewhere depending on the cold feed outlet some of the bungs don't seal completely do to the outlet
and lastly a complete drain of the system, i have a drain valve near the backdoor on the little rad and i have a couple more bottles of brand new inhibitor but im worried after reading a few stories that you can get air locks and its sometimes really difficult to clear them from the system so its kind of putting me off
The draining the system seems the most sensible but i really worried about causing myself some real problems that i then cant fix, the bungs i wont know if they worked (will I) until they are in and the valve im changing is leaking.
what you recommended method the diyer attempts to do this?
thanks
thanks
