Hi experts. Our Vaillant EcoTec Plus 824 combi boiler has had an intermittent fault for a long time (it's been discussed in the DIYNot forum, in earlier months). There does not seem to any certain cure for the fault, and mostly, I find that it must have failed first thing in the morning, when, at about one a.m., it is set to fire up after being merely on frost-setting for a while. If it did not fail (and sometimes, it does not), it would raise the water temperature to about twelve degrees until 7.00 a.m., when it should start to aim for a target temperature of 19 degrees. When I go into the bathroom at about 7.10 am, sometimes, the radiator is stone cold. So, on these occasions, it could have had no heat since about 1.00 am, when it failed to "wake up".
The reason for the above background info is that this boiler is housed in a kind of closet under the stairs. Access to it is via a door in the outside wall of the house. Draughts and cold air generally can go into this closet in winter (the door is not sealed at the bottom — there is a gap of about half an inch high) and, if the boiler has not ignited (let's assume the worst, and think that it failed to ignite at 1.00 am), it seems possible, at least, that in very severe cold, the pipes could freeze (a worst case scenario, I know, but...).
My question is this: if the worst did happen and the pipes to or from the boiler froze, would there be a build-up of pressure after, not knowing about a freeze-up, I manually ignited the boiler and it started to heat up? (I'm thinking explosions.) Or is the worst that could happen be that the pump would not be able to stand the load caused by such a blockage, and cut out?
With thanks in advance, for any helpful replies.
A.W.
A.W.
