Hello,
Was wondering if anyone could give me a step by step guide on how to re-pressurise my boiler and also bleed radiators?
Have detached a rad and reattached it.
Have not at this stage opened the lockshield valve nor bled the rads.
Do I:
Any help would be gratefully received.
Also once pressure topped up are there any things that i should be looking out for just to know that I’ve done it right. Of course will look for leaks on valves as I may not have tightened then enough.
Do I:
- Check all nuts are tight so no leaks
- Open lock shield valve (5 turns for me) - should i hear water filling the rad?)
- Open bleed valve using key? (turning anti-clockwise)?
- Run to the boiler and start to fill it with pressure using the filling key – aiming to reach 1.5 pressure reading?
- Then run back to radiator and close the bleed valve (clockwise)?
- Run heating then switch off
- Re-check boiler pressure to see if pressure stayed 1.5
- Check all nuts to check tight for no leaks.
- Open lockshield valve (5 turns)? Should I hear water filling the rad?
- Walk to boiler and repressurise using filling key until reached 1.5?
- Return to rad and open the bleed valve (anti-clockwise)? Listen for air coming out and look for water squirting out?
- Lock the bleed valve once water started to squirt out?
- Re-check boiler pressurise stayed at 1.5
