The wall is 10m long so I was advised to do 6inch hollows filled if I wanted to avoid building peers. Im guessing if I put rebar in them and drill down into the slab then I can fill them in stages.
Only problem is switching from concrete to mortar with my mixer means the odd few stones get into the mortar mix.
It could of been tony if I was any good at brickwork but as im not i'll go with the filling method. Im just a DIYer so try not to get too much out of my depth with these jobs. The slab is pretty thick 6-12inches and has reinforcing mesh and footings trench so it will be able to take the weight.
I have remeasured the wall and it is closer to 8.5metres if that makes any difference.
