Hi
Currently got a vented system with a Potterton RS80 from way back. The setup is dated and the controls I have are limited so I've finally decided to upgrade and will probably go for an Ultracom 35CXI Combi. Currently I have a Salamander CT75 shower pump feeding the shower only. No doubt this will have to go but what I want to make sure I get right is whether I get rid of the CWST in the loft and switch the CW feed to the bathroom/shower to mains pressure. The 35CXI states HW flow rate of 14lt/min. I did a test on the garden tap off the mains and it's around 20lt/min.
If I get rid of the CWST will this balance well and be enough to feed CW to the boiler & shower? Or should I keep the tank feeding the bathroom/shower even though I think the flow rate may be low and would therefore keep the pump for the cold water only?
Thx
Thx
