Do I grout the corners?
22 Aug 2018
ok a bit of a rhetorical question, i’ve already grouted the internal corners of the whole bathroom, including shower.
Should i cut the grout out or silicone over the top?
Take the grout out and silicone. Always silicone.
There must always be a minimum 3mm gap around perimeters to allow for expansion movement in the tiles. Without it there is a chance of tiles crazing, cracking or tenting.
Cheers Paul! I did think that after i put everything together, woops!
Is there a specific width of sillicone that should be on the tiles or is it just as long as the gap is filled?
Next question, how do i remove grout
Can I butt in please?
I was told by the man in the tile shop that I could grout the corner over the bath/shower position as I was going to be using a flexible grout. If I felt I needed to I could run a bead of clear grout over the top when grout had set
Now I’m confused.
Please advise
Now I’m confused.
Please advise
He's thinking a bead of clear silicone to seal the corners but personally I'd do one or the other.
My preference would be to use a colour matched silicone in the corners.
