We are planning a single storey rear and side extension to our smallish semi house.
The gas supply currently enters the house above ground and dpc through the external side wall into the under stair cupboard, which is where the gas and electric meters + electric fuse box have all been since the house was built in the 1960s. The supply pipe outside goes straight down into the original concrete side path, so I assume it runs underground out down the front drive to the mains supply.
Our proposed extension will run along most of the side wall of the house, including the point where the gas supply goes through the wall to the meter cupboard under the stairs.
I have no particular wish to move any of the meters from their original location, not least because of the cost of doing this. However, from browsing and reading up a bit, I gather that those responsible for the gas supply pipes REALLY don't like it if their pipes end up under floors.
Can anyone advise if it is possible for the gas people to move the point of entry for the supply to a new outside wall of the extension in line with the current direction of the pipe buried in the drive, and then reconnect to the original entry point for the existing meter via internal wall mounted pipes? Or does the meter HAVE to be as close as possible to the point the pipe enters the building?
If permissible the above feels like the simplest/cheapest way of getting round the problem, though I know there will still be some standard charge for it.
