Hi, tried looking for this in FAQ's etc, but drew a blank.
I need to replace the ball float valve on my cold water header tank. I could just do a like for like replacement. But I'm thinking I may use one of the newer WC cistern valves such as http://www.screwfix.com/p/fluidmaster-brass-shank-side-entry-fill-valve/49088
My reason for wanting to do this, is that the old 'ball' type valves have a 'progressive' shut-off where they slowly close as the water level rises. The flow rate of the valve reduces, getting slower and slower until eventually shutting off. The time can be quite considerable and all the while there is an annoying drip, drip, or hiss.
The newer WC valves have a (in my humble opinion) better system that provides near full flow right until the level is reached, then they shut off rather quickly. They also appear to be quieter.
Is there any reason I shouldn't use a high pressure side entry WC type float valve on my header tank?
Regards,
Glenn
Regards,
Glenn
