Okay folks, here's the story so far.
My system is an Myson Orion Fanfare 40 Si with the de facto standard three port valve, single circulating pump and domestic HW storage tank - wired as Honeywell Y-plan.
Its running about 13 rads due to extensions on the house, and system was in a bit of a sorry state when I took house over. (I'm aware thats probably a little too many rads for the boiler, but in practise it rarely needs to heat up the whole house due to the TRVs and it seems happy doing the heat from cold. Its the 'keep warm' bit I'm having a few problems with.)
Since then I've flushed the system with DB X400, and refilled with DB X100 inhibiter and DB X200 in system descaler.
I've fitted TRV's to all rads, apart from the one in the hall where the main room thermostat is, and in the main bathroom.
The rads have been balanced - my what fun several hours with clip on thermometers can be!!
I've also replace the thermostat with a Drayton Digistat to give me finer control as thats worked well for me at previous houses.
So far I'm happy and the system seems to be okay, but I've still not eliminated boiler noise - you can hear the kettling and bubbling - and pipework is noisy as the TRVs shut down. When the house is cold and the rads are pulling a lot of heat from the boiler it doesn't seem to have that problem.
Originally I thought the boiler was badly sludged and scaled, but its had the full flush (not power, just hosepipe!) and had X200 in for a season, and when the house is warm and few rads are running there is a fair amount of water rush noise.
I'd hoped by leaving both the bathroom and hall rads without a TRV I would provide enough bypass, but now I'm starting to wonder.
So where do I go from here?
One thought is that boiler is still scalled and I should try a slightly more agressive descaller.
Another is that its the TRV shutdown is sending the pressure and flow rates all over the place. I guess a modern install would have a bypass between the feed and return, but I really don't want to disturb the pipes, and I've no idea of a technique to set the pressure level properly without an actual meter.
I'm rather attracted to the idea of replacing the main pump (A British Gas rebadged job "VariHead II" - no idea what it actually is) with one of the Grundfos Alpha+ units and let that regulate the pressure/flow in the system. Anybody think this is a good idea, and would it drop straight in as a replacement?
And as an aside if I've balanced the radiators up, how do you ensure the flow rate in the boiler is right?
Cheers guys.
Cheers guys.
