Hello all I really need some advice.
Had a plumber replace my bathroom last August and he fitted a Hansgrohe Marin Centostat Bath/Shower/Mixer. Since it was fitted when you have the temperature between hot and cold it makes a high pitched whistleing noise. You can stop this by gripping the adjustment and putting pressure on it with your hand. It also stops if you turn the tap to fully hot or fully cold.
If i flush the toilet or turn on the cold tap on the basin it also seems to stop.
The hot is fitted to a combi boiler and the cold straight to the main. In the picture in the manual it shows a pressure reducing valve fitted after the stop tap which I dont have.
Do you think fitting the Pressure Reducing Valve will stop the noise. The plumber doesnt know what to do and told me to ring Hansgrohe but they have said that they will charge me £100 if it is not the tap and the installation?
If i have to have a PRV can you recommend one please?
Many Thanks
Many Thanks
