Hello.
I'm a landlord in Scotland and looking to replace wall mounted electric panel heaters with ceiling mounted Far IR heaters (Herschel). The current Dimplex 2kW panel heaters are wired to a fused spur, but they appear to be on the same circuit at the sockets in each room. (i.e. when I flipped the circuit breaker, everything went off). I thought heating circuits were normally different from sockets. I had an EICR completed last year, and the Electrician replaced the CU as part of that work, however he didn't comment on the heating/socket circuit arrangement so assuming it is ok?
To keep the costs down and to make it easier for my schedule, I want to mount the heaters / controller myself and connect it to the existing fused spur, the new heaters are only 700W as opposed to the 2kW previously. I won't have hidden wires, I will use trunking.
Does anyone know if this work would be considered an alteration to a circuit, and therefore need a certificate from an approved Electrician? I'm a little hazy to as what I can and can't do myself (i.e. can I change a light fitting myself?)
If I DO need a Cert, would it be appropriate for me to do ALL the donkey work myself, and just get the Electrician in at the end to literally connect the wires to the terminals in the existing spur and write a Cert? Say, 5 mins work for each heater?
Thoughts would be appreciated.
Thanks a lot.
Thanks a lot.
