Do i need DZR fittings?
14 Oct 2004
Hi all, as some of you may know in refitting our bathroom, but need to know; :confused:
1. How do i know if i need to use DZR tap fittings?, (i was going to use compression)
2. Do i need to use Parallel or Taper thread on the bath/sink taps?
DZR if you are planning to put the bath underground :LOL:
You need a tap connector or flexi for your taps.
Thanks.... Have you not seen the latest trend.. Underground baths.. :oops:
Why don't people like BES tell you what this is for, so it don't embarrass people like me, and waste time for people like you. :)
Hope I gave you a laugh mate. :LOL:
Use the flexis for your taps, fit the compression end to your pipe other end to your bath taps.
You will need 3/4 bsp one for your bath.
Post back if you get stuck ;)
...because BES is a trade supplier. There are several places you should use DZR fittings, especially iof you have soft water, or other reason for electrolytic action.
As you're buying from BES, use the cheap Italian fittings, they seem to be fine.
Given the amount of topics you are working Hep2o into, you must be on commision ! Speedfit for me....
Thanks for all your helps.
I did ask about plastic, but some (kev) didnt think it was a good idea.
So i've done it all in copper end-feed :)
(hope it don't leak!)
