i have had a beautiful new cabin built, but I am boarding it out myself. The structure is timber and is stuffed to the gunwales with Celotex. The walls have 150mm Celotex panels which leaves a 10-20mm air gap between the front of the Celotex and the front of the studs. I have been advised that the joints between the plasterboard and the studs should be foil taped, but given the fact there is an air gap, would it be best practice to use foil-backed plasterboard. The heating is going to be underfloor electric, and while I am aware this is going to be really expensive to run, I want to make sure I am being as efficient as possible with the insulation.
So:
1) Just bang on the plasterboard
2) Tape the stud work and then bang on the plasterboard
3) Use foil-backed plasterboard
Many thanks
OB
So:
Many thanks
OB
