Hi, was hoping for some advice from any roofing experts.
My roof has recently been sagging slightly at the back, i called a builder in who said the support bean had split in half and had a temporary/dodgy repair made in the past, with a shorter beam bolted onto the broken beam. Also the wall on on side in the loft was not built up all the way to the top, and so the roof was basically hanging in the air with no support from the walls. I have attached pictures of this. He said the entire roof had to be stripped, all tiles removed, new beams put in, and the one wall built all the way to the top, then tiles re-layed, at a cost of £6'500.
Another builder came and said theres no need to remove the roof tiles, just brick up the missing wall, and fit a new 4inch x 8 inch/10 inch beam slightly above the broken beam and fit it into the walls on either side. The quote for this work was £2'900. A huge difference in price.
Can someone advise which is the the correct option to take, and if planning permission will be needed for these jobs?
Any advice will be greatly appreciated
