do i need to drain radiators?
30 Apr 2004
on a baxi boiler,on the water feed to the boiler is a pushfit Magnetic Scale Inhibitor,this is leaking on both ends of the pushfit connectors,
the plan is to remove it and add some copperpipe in its place,customer does not want another,im guessing the previous fitters have not pushed the pipe fully home for it to leak after only just over a year,
im i right in saying i dont need to empty the rads before removing the Magnetic Scale Inhibitor.the feed to the boiler is isolated by a stopcock,
take it out cos its usless
and fit
You are right. Just turn off stop cock upstream of scale inhibitor, open hot taps to relieve pressure, and disconnect. Obviously a little water will spill out, but nothing much.
thanks guys,felt a little silly asking,of course the rad water does not flow back on mains water supply :oops: ,but better safe than sorry,not hard to sak on here,you u 's a drink again :D :D
