Hi all.
I'm renovating my bathroom and want to put a towel rail where a radiator once was. I've taken the radiator off so have the existing pipe work there with the valves still on (turned off)
I need to cut the pipes back and re-do the layout. I was hoping to have a plumber do this but they all seem stacked out!
I live in a bungalow and have a combi boiler (vallient eco tec) which has a drain valve under the boiler and one other drain valve under a radiator by the front door.
Do I power off the combi boiler, turn all the valves off for all radiators and open the valves on the pipe work for the pipes I need to cut back and drain? Then repressurise the system? Any help would be appreciated.
Thank you.
Thank you.
