I recently moved to a house with no gas supply, only electricity, and have a Myson Maxton slimline electric central heating boiler, which is used to heat water for supply to radiators within the house:
http://imgur.com/a/oe7ON
http://imgur.com/a/qXVUq
http://imgur.com/a/tiHxH
http://theinitiativegroup.org.uk/fs...son/MYSONMAXTONELECTRICMODELNosMB6MB9MB12.pdf
I needed to bleed some radiators and, after doing so, I thought I'd check on the pressure within the system to see whether it needed to be repressurised. But....I can't find an obviously visible pressure gauge on the boiler nor a filling loop!
Am a missing something obvious? In my previous house which had a regular gas combi boiler, I would occasionally repressurise by using the filling loop whilst watching the pressure gauge rise to the required level (i.e. 1 bar when cold).
The boiler currently operates ok, heating water for the house's radiators. Specifically, what I'm asking is:
(N.B. the boiler can be used for both central heating and hot water supply. However, I only use it for central heating. For my hot water supply I have an immersion heater in the loft above).
- If there were to be a leak in the future, or after I've bled radiators, how do I check the system's pressure?
- If the system pressure were to drop too far, how would I know and how would I re-pressurise it?
- If there is no way to manually repressurise the system, is it possible that it somehow automatically maintains the correct pressure?
