I would agree, however it is not what
@Zehroni is willing to do, but what the person who is raising the completion or complacence certificate is willing to accept. In my old house still have an adaptable box with two RCD's and two old Wilex fuse boxes supplied from them with MCB's fitted instead of the fuses, one plastic and one plastic and wood base, it would not strictly comply as non of the units are type tested, although since I am not an ordinary person that does not matter, and they are not flame resistance however since fitted in the garage where there is nothing to burn that does not matter.
However I am not doing major electrical work in the house, and so not looking at anything which will require a completion or complacence certificate, with a it is unlikely the work in some way does not need a completion or complacence certificate, likely both, and if one knows the LABC inspector is likely to visit if I was a scheme member electrician I would not want to do anything which he may pick up on, however I do wonder if the LABC inspectors walk around with their eyes closed, as the one inspecting this house allowed the fuse box to be located between ceiling and flat roof with a 9" square hole in ceiling which one could stick ones hand through to just about replace fuses.
So yes a mini consumer unit with a RCBO would do the job, but one is it worth it, and two will an inspector accept it?
Note:- A consumer unit is a type tested distribution unit for use when an ordinary person is in control.
So
Screwfix prices a 5 module consumer unit (garage or shower) is £29.99 and a 12 module consumer unit is £31.99 so the cost of parts is nothing really (both unpopulated) where the cost comes in is paying some one so you get a completion or complacence certificate be it the LABC inspector or a scheme member electrician, last time I came to do electrical work needing a completion certificate the LABC charge was over £200 and they wanted me to employ some one else as well to inspect after, after some talking they did in the end agree I could complete the installation certificate, but unless you can show you have the skill it will likely cost around £300 using the LABC route to do latter, and around the same using a scheme member electrician, so may as well fit whole consumer unit rather than a mini one as so little difference in cost now, and it will cost so much to change latter.
The LABC inspection is paid for in bands, depending on cost of work, lowest band is £2000 so that's why so expensive latter. It is not safety or electrical regulations (BS7671) I am thinking about, it is the cost of the paperwork if done latter.
