Do I need to seal my porcelain tiles?
22 Aug 2010
London
Hi Guys,
My bathroom is now done and all tiled with 30x60 porcelain tiles. These are not textured or fancy, but a matt looking black (floor) and beige (wall) tiles bought from B&Q.
Am I right in thinking that I must seal these, which will essentially protect and waterproof both the tiles and the grout and stop staining etc?
Can anyone advise on seals and applications? I don't want to change the matt appearance they have or give them a shine?
Not quite sure how I'd apply it without getting it on the bath and worktop etc
Generally polished & matt porcelain needs sealing but not all, what does the tile manufacturer recommend? If you’re not sure, do an absorption test; put some water on the tile and leave it for about 20 minutes then wipe off. If the surface shows a darker marking on the surface then you should seal.
http://www.tilecleaning.co.uk/SealingProducts.html#Sealers-Choice-Gold
http://www.extensive.co.uk/?gclid=CJGm4tHagqkCFYFB4QodFTlgRg
Just to be sure do a test on the tile first.
Hope you didn’t use white grout on the floor tiles ;)
Thanks Richard,
I will do the test, but have a feeling that the tiles them selves probably don't need sealing, but thought that sealign the grout may be worth it. Then again, no point doing all this if it's not required.
if needed sealing then you would of done so before grouting.......
if the grout hasnt stained tiles then shouldnt need sealing, but i still seal grout in shower/bath areas as soaps, shampoos, fake tans, hair-dyes etc are used everyday and can easily stain the grout :D
