Do I need to seal plaster before painting with bathroom paint ?
11 Oct 2016
Hi, I have some 1970s walls that I have stripped and sanded.
I am.planning to usedulux bathroom paint which I find usually doesn't soak in even when thinned with water
Should I seal the plaster first with something?
"General preparation: Remove any loose or flaking paint. Where necessary, wash the surface to remove dirt, grease etc. Treat surfaces affected by mould growth with a suitable fungicidal wash. Sand down to remove any sheen.
Seal new, bare and porous surfaces with a thinned coat of Dulux Easycare Bathroom+ (10% clean water). Porous surfaces, including previously unpainted patterned textured ceiling coatings, new buildings that have a plasterboard finish and wallcoverings that are suitable for painting (not vinyl or washables) should be sealed with Dulux Plaster Sealer for best results.
Stir thoroughly with a palette knife or similar implement before use. For normal use thinning is not required. However, in hot weather and warm environments, up to 10% clean water may be added and stirred in to ease application."
Don't use glue.
As said, don't use PVA. Some painters do have success with this - but that's down to them. Don't try it.
Don't use glue.
Thanks John, is there any chance you could look at my other post please?
I'm.not having much luck with that.
