Do i need to strip plaster before i dry line?
17 Jan 2010
Warwickshire
Hi
I have a 1903 solid wall terrace and im planning on dry lining the inside walls to improve insuration.
I am assuming i need to remove the old plaster right back to the brick before i apply the dry lining? But i thought i'd check on here first before i waste my time with a hammer and chisel.
Its a huge room so im not to fussed about losing an extra inch or so of the walls by not removing it. However i want to make sure im not going to generate an potential damp/condensation by doing it.
Any advise would be appreciate.
Cheers
Joe
i assume you are battening out the walls, so no you don't need to.
But the plaster behind the walls will decay in time, I personally would but I'm a fusspot.
I tapped some plaster in the corner to see firstly how deep it was and also how easy it if to remove. It pretty much fell off so i think i shall be doing it properly :)
also, will take no time at all with an SDS chisel, if it's bond with the wall is weak then there's no concern of damaging the brickwork with powertools.
