I'm about to install a carpet runner. The edges down the length are nicely done with binding tape. Do I need to do anything to the cut edges of the runner at the top and bottom and the cut edge of the landing carpet?
At the top:
Am I right in thinking that I will just be butting the top edge up against the bottom of the bull nose on the top step (i.e the bull nose of the landing)? If so, do I need to put some glue or resin on the cut edge of the runner or is it sufficiently out of the way of feet/hoovers that it won't fray?
There is a carpet on that top landing which I think I will be rolling over the top of that first bullnose and then tacking to the underside of the bull nose. So will the cut top edge of the runner actually be tucked up and protected behind the edge of the landing carpet?
Do I need to treat the edge of the landing carpet that will be wrapped round the bullnose and meeting the top riser?
At the bottom:
Do I just fold a few inches over and then tack it to the bottom riser without a gripper? Or should there be a gripper on the bottom riser too, and if so, how do I get a neat finish where the runner on the bottom riser meets the tiles of the entrance hall floor?
Edit: Oh, and if I do need glue/resin. Please can you kindly recommend a product preferably that I can readily get from a DIY shed or screwfix/toolstation - I'm not sure if local carpet stores are open for people to buy small items in lockdown.
At the top:
At the bottom:
