Hi guys
What a great find this site is; wish I'd sussed it out ages ago, it would have saved a lot of grief!
I have a small area in my utility room that I need to plaster. It presently consists of well-adhered plaster, some of which is painted, and has a few patch repairs, but is generally fairly level, However it has an exposed corner with no render or plaster beading, and as a result bits of the corner have broken away.
Going by advice I've found on previous posts on the 'plastering' part of the forum, I was proposing to diamond key the old plaster, apply a 5:1 water/PVA coat and then another coat just before plastering.
Assuming this is a satisfactory method, what I don't know is:
(i) should I apply a coat of bonding plaster and one of multi-finish when it's dry;
(ii) should I use a render bead (because it's deeper than a plaster bead therefore allowing 2 coats) or just a plaster bead; and
(iii) what's the best way of attaching the bead - nails, grab adhesive or plaster.
Sorry if these questions are a bit dumb, but I fancy having a go on this small area (which will in any case be partly screened by cupboards), so any advice would be really much appreciated.
Thanks a lot
Thanks a lot
