Hello. I've just had our plans accepted for a single storey extension on the rear of our property. The extension runs 9m across the rear of the house and out by 3.4m Max. This will give a pitch of around 17deg. The tiles can be used between 15 and 20 deg. I'm planning to put a lean to type roof, with 2 velux windows, just to make the extension feel bigger inside. I just can't work out whether i need a purlin to span the 9m or would I not need one if I used approx 3.6m 150x50 rafters with a 450mm spread. Any advice would be gladly appreciated.
Thanks.
Thanks.
