I have got 10 35w halogens in the kitchen on a dimmer. A couple have popped rercently so I thought Id try a couple of 'warm white' dimmable led jobbies:
http://www.simplyled.co.uk/GU10-LED...50-430-Lumens-50-watts-equiv_A11CDY.aspx?nh=1
http://www.ledhut.co.uk/spot-lights...umens-45-watts-equiv-best-internet-price.html
They are 50W equivlents but Id thought Id see how they stacked up.
They are indeed a bit too bright next to the 35W halogens (which isnt a problem) and are whiter but not in any way cold and the difference is obviously more noticable as you dim when the halogens put out a nice candle like yellow.
They dont flicker and the dimmer was not led specific and I assume this is because there is still plenty of halogen load in the circuit.
The issue (and question) I do have is that they will only dim down to a certain level and then stay at that fairly bright level when the halogens go much dimmer.
Will getting one of the recommended dimmers help this? Even if I have a mixed load of halogens and leds?
There is lots of info out there but nothing that seems to talk about this scenario. If I need to get a dimmer and swap out the whole lot Ill have to start saving!
Any help welcome.
Scott.
Any help welcome.
Scott.
