Do the olives in rad trvs restrict the flow much when crimping them up?
30 Mar 2012
Monmouthshire
I have some 8mm tails that need extending to the rad. Would it be of any benefit if I continued them to the rad valves with 10mm?
i am almost certain 10mm pipe will fit onto 8mm pipe
Yes you’re right DP , done it a few times, usually when someone has nailed an 8 mm pipe, works like a big slip socket
