I allways use 1.5mm t&e, yet fuse a 6A as I have just allways used 1.5mm t&e + the fact that it could be upgraded to 10a should the need arise.
I used to use 16mm patresses but i dont like how deep the MK Logic Plus range are and the limited room for the cables needed for two way lighting on a double gang switch (especially if circuit cables are with it..)
I know some people smash the hole far too deep and use longer screws, however I prefer to have the box just below the level of the plaster. Im increasingly just using 25mm patresses now (I also like the fact I can fit more grommets)
Im assuming everyone else just uses 25mm patresses and ive been struggling for far too long?
